Sectorial moment of inertia (I omega) in Section Builder and Steel design module
6 REPLIES 6
Jummybear
9315 Views, 6 Replies
Hi guys!
Is it possible in robot to calculate section sectorial moment of inertia in section defenition module? I didnt find it, probably was looking in wrong place or its not possible?
@Jummybear Artur Kosakowskiedited the topic for better findability
6 REPLIES 6
Yes, providing you define a section as a thin walled one.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Ok, but if i want to get sectorial moment of inertia of some section from database? I cant define it like thin walled section... Or i should redraw section by hand te get that moment? Looks like not very logical way 🙂
Rafal.Gaweda
in reply to: Jummybear
Why illogical? Robot does not use iomega for some families so there is no such data for them.
Rafal Gaweda
Jummybear
in reply to: Rafal.Gaweda
Really? And what about laterial buckling controll? It and Iw showld be taken into cansideration
Rafal.Gaweda
Example, for IPE
Rafal Gaweda
For steel design module this value is generally calculated according to the provisions (formulas) from the code itself (the selection of the formula to be used is governed by a section symbol assigned to a particular section). Mind that LTB is checked only for selected section types (again this is governed by section symbol). The value from the database is used only when the steel design code itself doesn't provide the necessary formulas.
Artur Kosakowski
Technology Administrators
