Bonjour,
C'est quoi le problème de (memoire insuffusante) sachant que robot 2012 est installé sur une machine 32 bits
How much memory do you have in computer?
Have you set "3 GB switch" ? http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8018966&linkID=9243099
How big is the model?
set "3 GB switch" -> http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8018966&linkID=9243099
Check task manager how much total memory is consumed.
I strongly recommend to use compter with 64 bit processor, 64 bit system and 8+ GB RAM
