Section shape
Section shape
waseem-eng
Section shape
waseem-eng
Hii
why the sections still thin (with no extrude ) when i activate section shape?? as in picture2015-01-07_110739.jpg
Artur.Kosakowski
Autodesk Support
Autodesk Support
Check the units of a model. My assumption is that you e.g. set them as meters whereas you entered the values for mm instead.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
waseem-eng
thank you for your reply
i have attached template file because i couldnt find mistake
Artur.Kosakowski
Autodesk Support
Autodesk Support
The most likely scenario is that you edited the database changing its native units which resulted in rescaling the sections. Please try to search for the file name and replace the files on your computer with the attached one. Then create a new project with the same section.
Artur Kosakowski
waseem-eng
thank you for your help
i restored program to Default parameters so every thing get ok
