Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
second order analysis (no convergence)
10 REPLIES 10
Message 1 of 11
admamouhiba
679 Views, 10 Replies
I have read all the threads mentioning the P-delta analysis and second order effects. However I can't find a solution to the convergence problem in my model, I have changed the tolerance and the increments number too. But I always get a bunch of instabilities and the "no convergence" error.
please note that I did not have any instabilities with the buckling analysis, and I discretized all the model elements for more precision in the buckling results. I find that for the first mode the critical factor<3, which means my structure is "sway" and that I need to take into account the non linearity . I have created a seperate load case "second ordre" which is the same as "ELU+" , the  load case I am interested in. and I set the first mode I obtain from the buckiling analysis with "ELU+" to be the initial deflection for the non linear analysis.
I don't know why I cannot attach my robot file, but here are some screen shots. I apprecaiate any help.
Thanks in advance.
@Pawel.Pulak @mustafahesenow
10 REPLIES 10
Message 2 of 11
Hi @admamouhiba
Share model for verification. Save it as RTD without results then Zip before sharing.
Krzysztof Wasik
Message 3 of 11
Thanks for the reply @Krzysztof_Wasik
here is the file.
Message 4 of 11
Hi @admamouhiba
Shared file does not contain any model. Try onece again
Krzysztof Wasik
Message 5 of 11
@Krzysztof_Wasik
I hope it works this time.
Message 6 of 11
HI @admamouhiba
In this case I would recommend switch ing off DSC option in Job preferences. Keep in mind that forces applied in case 10 are bigger than buckling load
Krzysztof Wasik
Message 7 of 11
I am afraid that does not solve the problem @Krzysztof_Wasik . if you look at attached screenshot, critical factor is 1.28, which means load case 8 needs to be multiplied by 1.28(I understand it's very small) to reach the buckling load, meaning it's not bigger than buckling load.
one more question, why do I get instabilies after running the P-delta anlysis and what does the "no convergence" mean? and what happens if the load case is bigger than the buckling load?
Message 8 of 11
Hi @admamouhiba
In your model second order analysis is set for case 11. which has loads much bigger than in load case 8
When DSC is off case 11 converges, so results can be obtained for all load cases.
Could you explain problem with more details.
Krzysztof Wasik
Message 9 of 11
I see thank you so much. But shouldn't DSC be on because  I have releases in my model?
Message 10 of 11
Hi @admamouhiba
When in releases fixed/released setting is used (no elasticity and nonlinear behavior are defined) DSC might become deactivated while analysis.
Krzysztof Wasik
Message 11 of 11
Hello @Krzysztof_Wasik ,
Why is it that when I define the buckling deflection L/200, I get instabilities and the calculations don't converge? Please note that I corrected the load for the non linear analysis to be the same as for the buckling analysis.
Thanks a lot.
Technology Administrators
