Good day all, first post here.
I am designing a structure for various sinkhole conditions and want to run multiple variations of support conditions on a single structure. Then generate results for each to compare them at a later stage. I understand that this will take long either way, but can anyone suggest a way of automating this? Can it be done using API’s or Dynamo?
Hi @Wlrstopforth ,
You can try to use phases to keep all options inside one model. However, phase structures are not compatible with API.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
You can follow the good @Romanich sugestion or , if it is a small/medium structure model , you can put them all side by side by just copying the original model multiple times and then edit the supports on each of the copies.
Rafael Medeiros
