Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Running Concrete Non Lin Deflections in 2016
7 REPLIES 7
Message 1 of 8
383 Views, 7 Replies
I am having trouble running the verification of my RC slabs in 2016.
I don't get the pop out to run the calculation after running the verification.
I do get errors in the verification (for too little AS), which i was previously able to ignore in 2015, as they were very high concentrations in very localised areas around the tops of columns.
Does 2016 not allow you to run the NL deflection calc for models with errors?
Timo
7 REPLIES 7
Message 2 of 8
Please let me know if you need any more info / explanation to help with this...
Message 3 of 8
Rafal.Gaweda
File please.
Rafal Gaweda
Message 4 of 8
in reply to: Rafal.Gaweda
Please find attahced an example.
Via drop box link
https://www.dropbox.com/s/elzbmpu6lltyrcz/13th%20Floor%20Slab%20Model%20Current.zip?dl=0
Message 5 of 8
Rafal.Gaweda
Oh, OK, clear now.
You are right. Verification window does not appear after closing window with warnings.
It must be checked by developers. Thanks for reporting.
Rafal Gaweda
Message 6 of 8
Ok,
No problem, do you know what the likely ETA is for a work a patch?
Also, is it possible to copy Reinforcment maps from one model to another? I am running multiple instances of the same model to check my reinforcement for various conditions...
Message 7 of 8
Rafal.Gaweda
1. I do not know
2. No
Rafal Gaweda
Message 8 of 8
Corrected in SP4 for RSA 2016.
Artur Kosakowski
