I am having trouble running the verification of my RC slabs in 2016.
I don't get the pop out to run the calculation after running the verification.
I do get errors in the verification (for too little AS), which i was previously able to ignore in 2015, as they were very high concentrations in very localised areas around the tops of columns.
Does 2016 not allow you to run the NL deflection calc for models with errors?
Timo
Solved by Rafal.Gaweda. Go to Solution.
Please find attahced an example.
Via drop box link
https://www.dropbox.com/s/elzbmpu6lltyrcz/13th%20Floor%20Slab%20Model%20Current.zip?dl=0
Ok,
No problem, do you know what the likely ETA is for a work a patch?
Also, is it possible to copy Reinforcment maps from one model to another? I am running multiple instances of the same model to check my reinforcement for various conditions...
Corrected in SP4 for RSA 2016.
