RSA2016 nodes - Graphical problem
Rafacascudo
Mentor Mentor
Message 1 of 14
Rafacascudo
Anybody else having this?
I Only have nodes in the window (XY projection) , everything normal (left pic) , buf if I turn off the supports showing , or go to a XY plane where there are no supports ,even with supports showing turned on , the nodes will almost vanish(right pic). Very hard to visualize them on screen!!!!
Everything works normally if I have nodes + panels or objects like polylines.
Nodes also "disappear" if I have nodes + bars
Antialiasing turned off on Robot and on Graphic card setup, openGL on , default acceleration , selected nodes turned to green , selected bars and panels to red.
Everything else on default
Rafael Medeiros
Replies (13)
Message 2 of 14
Romanich
It is a really annoying issue in Robot, that user cannot change the visual size of the nodes.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 14
Rafacascudo
Hi Romanich,
Node size never bothered me at all until now.
I was starting to use RSA 2016 when this happenned and made me come back to RSA 2015 as it become really difficult to model without visualizing the nodes.
But I know this is a local issue because in a coleague´s computer just beside me ,everything is fine.
That´s why I asked if anyone else had had this.
By the way , probably you already know ,but just in case  , node size will be increased when you set symbol size at 60(60 to 100,same size) , although it will turn into a blue little square and when you select it will keep it´s original green round size. Labels ,of course, will be huge!!!!Smiley Surprised
Rafael Medeiros
Message 4 of 14
StefanoPasquini6790
Hi dear Rafacascudo,
why don't you try to rename the CfgUsr folder? It can be a problem related to you personal settings in visualizing...
Good luck, cheers
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 5 of 14
Rafacascudo
Thx Stefano , but it remains the same thing.
Here is the " magic" Smiley Frustrated
Watch in full screen if it is not clear
Rafael Medeiros
Message 6 of 14
StefanoPasquini6790
try to repair the installation of ARSA2016....this is the last chance!!!
Cheers
PasProStudio
Message 7 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you try to edit registry of RAS 2016 and set:
HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\29.0\Viewer*MSAA-Enable* false
Artur Kosakowski
Message 8 of 14
Rafacascudo
no effect .It remains the same
Smiley Sad
Rafael Medeiros
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
In addition to the change in the registry:
1. Rename mview.dll file in System\Exe folder of RSA 2016
2. Unpack and copy the new version of this file there
The above change was included in SP2 for RSA 2016. Please download and install the latest SP for this version from:
https://knowledge.autodesk.com/support/robot-structural-analysis-products/downloads?release=2016
Artur Kosakowski
Message 10 of 14
Rafacascudo
It seems to have worked. If not , I´ll report later.
thx Artur!!!
Rafael Medeiros
Message 11 of 14
How can I edit the registry?
Is this a file? In what folder is located?
Message 12 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Use registry editor:
Rafal Gaweda
Message 13 of 14
I've change the registry and also pasted the new mview.dll. Although the nodes are a little bit more visibles, I'd like even bigger. How can I change it manually?
Message 14 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Press a few times PageUp key on keyboard.
Rafal Gaweda
