code parameters for bolted connection
Here, in one example code parameters for bolted connections are available, and in one examle this option is not available. Why is it so? Where this option is not available how does it select the Type of analysis and category due to shear ?
1)
2)
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid I still do not get it.
Are you refering to screen shot 1 or 2 or both ? What is "not available" on them?
In general - if not available = not implemented
Rafal Gaweda
If you say not implemented, then how to categorize bolts and decide the type of analysis?
Rafal.Gaweda
Autodesk Support
Autodesk Support
For those connections where you do not see "Code Parameters" they are always treated as type A
Request to implement other types is registered in dvlp database to consider it in future development plans.
Rafal Gaweda
and type of analysis????
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you have any or could you indicate any references where it is explained how to calculate stiffness of such connection type?
Artur Kosakowski
I DONT
