(API) Extracting results to excel through ROS
Hey
I am extracting the bending moment and normal force from a model of a slab. There are around 3000 nodes so it takes quite sometime before I have the results. The process is done for the design load combinations
Any advice of how to speed up the process in general. My code look like this.
_____________________________________________________________________________________________________________________________
Option Explicit
Private Sub CommandButton1_Click()
CommandButton1.Caption = "Extract results"
CommandButton1.Font.Size = 10
Application.ScreenUpdating = False
Dim Robot As New RobotApplication
'Extracting all Nodes
Dim NodeCol As RobotNodeCollection
Set NodeCol = Robot.Project.Structure.Nodes.GetAll
Dim RNode As RobotNode
Dim ii As Integer
Dim row As Integer
row = 27
For ii = 1 To NodeCol.Count
Cells(row, 1) = "Node"
Set RNode = NodeCol.Get(ii)
Cells(row, 1) = RNode.Number
Cells(row, 4) = RNode.X
Cells(row, 5) = RNode.Y
Cells(row, 6) = RNode.Z
row = row + 1
Next ii
'CALCULATION: Command to activate calculations
'Robot.Project.CalcEngine.Calculate
'RESULTS - EXPORT
Dim TheResults As RobotResultServer
Set TheResults = Robot.Project.Structure.Results
' Result parameters for panels
'Dim panelcuts As RobotPanelCut
'Extracting the name of panel cuts
'InOut.Cells(22, 1) = TheResults.FiniteElems.panelcuts.GetName(1)
'Setting the result parameters
Dim param As New RobotFeResultParams
' Calculation methode for reinforcement
param.CalcMethod = I_RCM_WOOD_ARMER
' Setting direction of local x
param.SetDirX I_OLXDDT_CARTESIAN, 1, 0, 0
' Layer of FE Element
param.Layer = I_FLT_MIDDLE
Dim N As Integer
Dim i As Integer
Dim j As Integer
Dim NumRows As Integer
For i = 3 To 31 Step 4
' Load case
param.Case = Workbooks("Shell Design.xlsm").Sheets("Myy-Top").Cells(24, i)
NumRows = Workbooks("Shell Design.xlsm").Sheets("Myy-Top").Cells(27, 1).End(xlDown).row
For j = 27 To NumRows
'Node
param.NODE = Workbooks("Shell Design.xlsm").Sheets("Myy-Top").Cells(j, 1)
' Structural panel
param.Panel = Workbooks("Shell Design.xlsm").Sheets("Myy-Top").Cells(12, 1)
Workbooks("Shell Design.xlsm").Sheets("Myy-Top").Cells(j, i) = TheResults.FiniteElems.Complex(param).MYY_TOP / 1000
Workbooks("Shell Design.xlsm").Sheets("Myy-Top").Cells(j, i + 1) = TheResults.FiniteElems.Detailed(param).NYY / -1000 ' The - is to turn compression to positive for the use in the design shhet
Next j
Next i
Application.ScreenUpdating = True
End Sub
______________________________________________________________________________________________________________________________
Thanks in advance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am not sure if i helps but you may try:
'somewhere at the beginning of function
Robot.Interactive = 0
Dim FER As RobotFeResultServer
Set FER = TheResults.FiniteElems
'then use FER.Complex... FER.Detailed...
'at the end of function
Robot.Interactive = 1
Rafal Gaweda
Thanks, this helps a bit.
