Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RSA freezes in calculation mode
6 REPLIES 6
Djokaboris
364 Views, 6 Replies
Hi;
When running the calculation RSA display overlap panels but freezes in the calculation process, so i can't detect those panels.
6 REPLIES 6
hi @Djokaboris
Probably due to the initial geometry you imported into Robot, the gaps between elements have not been filled since, and cannot be filled without your intervention.
Even if you've set your tolerances to 10mm instead of 1mm, that doesn't mean you don't have to connect your bars and panels together.
You should try to take all the gaps one by one and try to resolve them even when the gaps are less than 10mm.
Stephanekapetanovic_0-1715223498581.png Stephanekapetanovic_1-1715223580541.png Stephanekapetanovic_4-1715223892895.pngStephanekapetanovic_5-1715224045305.png Stephanekapetanovic_3-1715223742711.png Stephanekapetanovic_2-1715223661144.png
https://forums.autodesk.com/t5/robot-structural-analysis-forum/instability-issues-in-the-rc-model/td...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/load-transfert-from-slabs-to-beam/td-...
Best Regards
Hi Sir @Stephane.kapetanovic
please can i get the report of the new rtd file🙏?. i can't detect those gaps in revit
hi @Djokaboris
It's not easy to work in this order, because once you've redone the wrong joints, you'll have to confirm again that everything has been done. I advise you to first take your geometry to make your current Revit model a Robot calculation model.
Best Regards
Simau
in reply to: Djokaboris
Hi @Djokaboris
When you run your model, stop it at the first warning then delete overlapping members #389 and #420.
In addition to what @Stephane.kapetanovic said, there is something strange in you model as these walls in the picture beow are not shown in the object inspector.
M. Agayr
Djokaboris
in reply to: Simau
Hi Sir @Simau
Surely because the one's not selected are retaining walls and the others are load bearing walls. Don't know why it isn't assigned in the object inspector of RSA.
