Hi everyone,
I'm trying to perform a tubular joint check according to Norsok N-004. Therefore, I'm need to extract moments in a chord (members 103 and 104) and a brace (member 27). However, my brace is at an inclined angle to the chord.
Is it possible to rotate the local coordinate systems in the chord members as shown in the diagram below? This is because I want the chord's My moments to be in the same orientation as the brace's Mz moments
James
Solved by Stephane.kapetanovic. Go to Solution.
hi @jhe55NCY
there's a way by programming
in that case the macro transform forces from secondary beams as reactions in global axis but you can modify it to invert to main beam local axis. (collision plane)
Best Regards
Or you can use the Gamma angle orientation to a node
Indicate the upper node of the brace.
Geometry/Properties.../gamma angle
Rafael Medeiros
