roller suport in one direction
me1205377
me1205377
Greetings all and happy new year
is there a way to define a roller support that for example only resist translation in  -ve Z  but not in +ve Z
without getting in nonlinear analysis
moustafa elgaar
Rafacascudo
No way but this analysis will not include the pdelta effect (unless you mark it) , only the fact that with unidirectional supports the structure behaviour is not ... linear.
For example a load case like wind that causes this unidirectional support to function. For the wind on the opposite direction , this same suuport will not work and acting forces will have to be resisted by other available supports
Rafael Medeiros
mustafahesenow
Hi @me1205377
What you have mentioned above is Geometrical none linearity . So For sure there will be nonlinear analysis and iterations .
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
