Robot Time History Maps
Has anyone out there found a way to view the output of a time history analysis as a map? I would like to display max or rms acceleration for an entire floor plate from a time history analysis. In this case a jumping load has been applied simultanously over multiple nodes.
I guess that I am looking for a way to display the acceleration output in a similar way to the footfall analysis result maps, and at the moment I can only find a way to do diagrams and tables for specified nodes.
Apologies if the answer is already out there, I've searched through the forums but couldn't see anything!
Many thanks,
Ian
Artur.Kosakowski
Autodesk Support
Autodesk Support
Not available in the current version of Robot and registered on the wish list for the next versions. See: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/THA-Harmonic-FRF-results-Development-Request...
Artur Kosakowski
