Error in Library Structure
Message 1 of 8
Hello
I have problem with the follwing command in Frame 2D Desinge mode:
Geometry Menu, Structure, Insert from the Library...
After I select one of the structure, for example "Triangular truss type 1", and change the prameter and finally click OK to finish task, I will see an error.
"Erros in the file, Do you want to see them ?"
Can anyone help me?
Windows XP SP3
ARSA 2013 v26.0.0.4254
Please see attached file.
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
What is your default material setting in Job Preferences? What section databases are declared?
Artur Kosakowski
Message 3 of 8
Thanks for your reply...
I don't change any settings, all settings are in default mode:
Please see attached files.
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try either to add US section database in Job Preferences or change the default sections to others (European).
Artur Kosakowski
Message 5 of 8
I change section database in Job Preferences and the Error does not come anymore. But I forget to say, I also can not change Sections(the buttons that you highlighted in above picture). When I press "..." nothing happened.
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to delete temp Windows files and rename your CfgUsr folder. If this doesn't help insert the truss with the default sections and replace them afterwards.
Artur Kosakowski
Message 7 of 8
It doesnt work. I use defualt section and repalce them afterward, as you mentioned. Thank alot.
Message 8 of 8
really thank you very much
