Robot Structural Analysis Results of load combinations
ahmed.kamelTT2HV
ahmed.kamelTT2HV
I've made a model using Robot Structural Analysis, includes some loads, nodal loads, modal analysis and response spectrum cases, I have an issue in showing the envelope values of any straining action or displacement for a set or all load combinations, I only can see the result for each load combination but no envelopes. Any Ideas what I am missing?!
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @ahmed.kamelTT2HV
Check if results for each combination are available. If they are available for each combination zip and share model for verification.
Krzysztof Wasik
ahmed.kamelTT2HV
Hi Krzysztof Wasik,
Yes the results for each load combination is available. please find attached the zip.
Thank you!
Ahmed
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @ahmed.kamelTT2HV
It seems that model structure is corrupted.
Repair your model by copy/paste all objects to new empty project  in second opened Robot instance
Krzysztof Wasik
ahmed.kamelTT2HV
It looks strange for me to have this type of error or corruption, and seemingly is impossible to know the reason so it can be avoided in future, anyway, I applied what you proposed and it works! if you have in recommendations to avoid this issue in the future, kindly inform me.
Thanks for your support!
kind regards,
Ahmed
Krzysztof_Wasik
Autodesk Support
Autodesk Support
I cannot reproduce the way model was created.
Since each of combination is defined four or five times, I guess that you could youe some not typical workflow for model generation.
Krzysztof Wasik
