I used the FO field of a calbe to define the initial tension in the cable.
The software obviously does not consider the force F0 as an initial tension in the cable but as the projection of the final
load in the cable projected on the undeformed position of the cable.
my model is pretty simple: 14m horizontal cable. section 1.33cm2, E=1886 MPa.
the cable support a vertical distributed load of 0.26kN/m.
introducing F0 = 2.5kN Robot computes
deflection = 259.8cm, F in cable= -3.09kN , reactions: Fhorizontal = 2.5kN, Fvertical=1.82kN ??????
introducing F0 =0kN Robot computes
deflection = 125.5cm, F in cable= -5.48kN , reactions: Fhorizontal = 2.5kN, Fvertical=1.82kN
now introducing the initial tension via a thermal shrink of the cable
deflection = 105.5cm, F in cable= -6.42kN , reactions: Fhorizontal = 6.16kN, Fvertical=1.82kN
which is the correct value.
I believe there is a problem with the assembling case !!!
Many thanks in advance, to check / advise !
Benoît
