Robot Structural Analysis Professional 2023 released
okapawal
Autodesk Autodesk
Message 1 of 9
okapawal
Dear All,
The Robot team is happy to share the newest Robot Structural Analysis 2023 release with you.
Robot Structural Analysis Professional 2023 has been released via Autodesk Accounts and Autodesk Desktop App on April 7th.
      • Dynamo Extension for RSA 2023
      • Robot-Advance Steel Link 2023
      • Composite Beam Design add-in 2023
Thank you all for your support.
Regards
Autodesk Robot Structural Analysis team
Waldemar Okapa
Sr Product Owner
Replies (8)
Message 2 of 9
bartolome.tavera
Hello, I want to know why this model shows Error 100
Building: 39 floors
 https://drive.google.com/file/d/1fn5bE6u645R5EKYn4z7g6DJgsvAyJSc_/view?usp=sharing
Why doesn't the program show "reduced forces" results for the SX spectral case?
Thank you.
Message 3 of 9
okapawal
Hi @bartolome.tavera
Open the model using "Repair Mode" it solves the error 100 issue
It looks like there are the reduced forces, mostly FX, for SX spectral case.
Waldemar Okapa
Sr Product Owner
Message 4 of 9
bartolome.tavera
Perfect, Thank You
Message 5 of 9
manuel.gomes
Hi @okapawal,
Can you please help me in one question?
When we perform a spectral analysis, Robot has the possibility of specify the acidental eccentricity. In a seismic analysis, in some codes too. But on other codes like NP EN 1998-1:2013 (Portugal EC8) Robot simply doesn't have that option. Do you have any idea why and how to solve it?
Thanks!
Message 6 of 9
okapawal
Hi @manuel.gomes
Sorry, it is our oversight.
We have implemented seismic analysis according to  NP EN 1998-1:2013, but eccentricity is missed in this design code.
Are you able to use EC8 General seismic code instead?
Waldemar Okapa
Sr Product Owner
Message 7 of 9
manuel.gomes
Hi Waldemar Okapa @okapawal,
ITank you for the fast answer.
In fact, if i use the seismic analysis EN1998-1:2004/A1:2013-General, and introduce manually the spectrum parameters, it works and the results seems correct, and we can introduce the seismic eccentricity.
However, in this way, the NP EN1998-1:2010/A1:2013 introduced in Robot in 2023 version, since it does not allow to introduce eccentricity, which is mandatory by the code, becomes obsolete.
Kind Regards,
Manuel Gomes
Message 8 of 9
karim.gassara
Bonjour, je veux comprendre l'utilité du module descente de charge (nouveauté Robot 2023),et s'il est applicable pour l'étude d'une charpente métallique, car à mon avis il est développé pour les structures en béton armé !!!!
Moderator note, English translation added:
Hello, I want to understand the usefulness of the load descent module (new Robot 2023), and if it is applicable for the study of a steel structure, because in my opinion it is developed for reinforced concrete structures !!!!
Message 9 of 9
steevenyoussa
Moi également c'est ce que je pense
That's what I think too
