steel Column verification and design
Michele100100
Michele100100
I have a problem with design of a steel column: Robot doesn't take the maximum value of Forces for the design? Why?
It happened sometimes, and I need always to imput manually values...There is anyway to do it automatically?
In the model attached, column n. 5 have different values of maximum forces:
Combination 1to62, I read N = 30, Fy = 22.31KN, Fz = 20,90KN, My = 25.88KNm and Mz = 17.43 KNm, very different from the design table results. Why? Where I'm wrong? Any help? thanks
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Michele100100
You probably found extreme forces in forces table.
Robot checks each load case separatelly, while your values are taken from different load cases (12 and 13)
Also maximum force value (in point 1) can cause smaller capacity ratio than in pint (2)  if in this  point force is smaller but buckling/leteral buckling length is bigger.
Krzysztof Wasik
Michele100100
Hello, thanks for the fast reply.
So Robot take the worst combination and not using envelope of all combinations.
