Robot Structural Analysis 2020.1 Update
okapawal
Autodesk Autodesk
Message 1 of 15
okapawal
We have just publishes Update 1 to Robot Structural Analysis 2020.
You should be notified through Autodesk Desktop Application and Autodesk Accounts.
The update addresses issues with the user interface display on high resolution monitors. It enhances reliability and corrects many other issues that users may encounter.
Here’s the link to the complete Release Notes document.
We hope you enjoy this update and always welcome and look forward to your feedback.
Robot Structural Analysis Team
Waldemar Okapa
Sr Product Owner
Replies (14)
Message 2 of 15
I'm pleased that the reinforcement shift after element update is addressed - - a problem I highlighted recently 😊
"Corrected the calculation of crack width for slabs according to EN 1992-1-1." I think this deserves some more explanation. Without any other context, I can't tell if the crack width calculation was previously COMPLETELY wrong, or just a minor tweak to a unique condition.
Message 3 of 15
okapawal
This issue concerns the calculation of reinforcement density ρp,eff for tension elements in some conditions.
See detailed description in the attached document.
Waldemar Okapa
Sr Product Owner
Message 4 of 15
zeeblake
Thanks thanks thanks thanks!!!!!!!!!!! 😊
Message 5 of 15
zeeblake
I tested the update on a high resolution display, and it seems more fixes and more debugging still needs to be done. I found bugs like:
  • Screen flickering to black while creating beams/columns on plan view and dragging it (and rule numbers becoming a mess).
  • The projections in the three planes (XY, XZ, YZ) are not properly seen when creating beams/columns in the perspective view.
NOTE: If the screen resolution was decreased, these bugs disappeared.
Message 6 of 15
rokas_varanauskas
 Me and few other colleagues are having issues with Robot 2019 and 2020 being both installed on the system. 2019 is running fine and has all updates installed. If 2020 is installed without 2020.1 update, everything seem to work OK when switching from 2019 to 2020 version and vice versa. However once 2020.1 update is installed, regardless of which version is started, there appears to be conflict between two versions.
I have attached screenshot where starting 2019 version required component registration which then went for a long time starting 2020 installation. This process is never successful and if terminated then version 2020 becomes uninstalled.
Sounds complicated, but hopefully makes sense.
Any suggestions how to overcome this would be greatly appreciated.
Kind Regards
Message 7 of 15
Can you please send the direct link to download the update ?
I am not able to find the link in my autodesk account ?
Thanks.
Message 8 of 15
Still, the erroneous report of the steel design using SLS checks are not corrected?
Message 9 of 15
zeeblake
What's this erroneous SLS report problem? I wasn't aware of it. Can you point me to some post explaining the problem? (I'm very interested, because I'll be doing steel calculations in the next months, so I'd like to be aware of any known problem). Thanks!
Message 10 of 15
In the next update can you please consider implementing a shared parameter(id) such that it will be unique in between Revit and Robot and could be reached out via API.
https://forums.autodesk.com/t5/robot-structural-analysis-ideas/revit-robot-bim-interoperability/idi-...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/revit-amp-robot-ids-mapping/td-p/5838...
Message 11 of 15
tony.ridley
When we look at the version in Robot, how do we know if the new update is applied?
Message 12 of 15
tony.ridley
bump
Message 13 of 15
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi Tony,
Robot 2020 without any update - Version: 33.0.0
Robot 2020 with Hot Fix 1 (see this link) - Version: 33.0.1
Robot 2020 with 2020.1 Update - Version: 33.0.2
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 14 of 15
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi
Version 33.0.2.7011 includes latest available Robot update
Krzysztof Wasik
Message 15 of 15
tony.ridley
