Robot's not letting me create things
Message 1 of 22
I need some help because I haven't found anything on the internet that resembles what's happening to me. This is my first time using this software, but the program won't let me create anything at all!!!! I can't create bars. I put the beginning point and then when I clik the end and nothing happens!! It doesn't create the bar, but there's no error. Also, I was only able to create one column, then it didn't let me create anything else. I tried on 2D frame, on building analysis and... well, nothing!!! I'm trying reinstalling, but any ideas on the topic would be super helpful!!!!
Replies (21)
Message 2 of 22
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to attach a movie that shows what is happening while you start using Robot so that we have a better understanding of a situation.
Artur Kosakowski
Message 3 of 22
Mirko.Jurcevic
Try to reduce display acceleration slider.
Set it as shown in the picture.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
Via BIM: apps.viabim.co
Try my Revit add-ins: Via BIM Tools
Message 4 of 22
I can't make a video, I don't have any software for that... And there's not
much to see anyway. With columns I can create just the one. When I click to
create another, it just won't let me, it won't do anything. With I click on
the icon of bars, the dialogue box where I can pick the materials and
sections appears, and I can click for the beginning of the bar, but when
I'm going ti click the end point, it won't do anything again. It's like the
program doesn't realize I'm clicking everywhere to try to create the bar...
It's super weird
Message 5 of 22
I have no idea what you mean by that... :S I'm a total newbie...
Message 6 of 22
I think I just understood what's happening. Everything I create (I tried creating objets like arcs and circles), it doesn't matter where I click it's like I'm only doing it on one point, which is 0,0... Hmmm, this is hard to explain... The beginning and ending point of everything is 0,0!! It's doesn't matter if I specify something completely different. I create a node, it goes to 0,0. I create a column, it goes to 0,0. I create a bar, the beginning and end point is 0,0. That;s why I can't create anyhting...
Any ideas on how to fix this?????????
Message 7 of 22
Mirko.Jurcevic
Here, download Jing. It's free software for screen recording:
http://www.techsmith.com/jing.html
Try to record what you've been doing and share the video.
Mirko Jurcevic
Message 8 of 22
Try Creating Axis system first, you should be able to see the Grid Lines. Then try to model along those lines.
Message 9 of 22
ok so I did it, thank you for the software suggestion
Here's the link to the video. Thank you for your help
http://screencast.com/t/rNPE8AKZO6Q
Message 10 of 22
I already tried that, it still does the same thing
Message 11 of 22
Mirko.Jurcevic
Try to delete contents of CfgUsr folder.
Turn Robot off before that.
CfgUsr folder location:
C:\Users\"yourUserName"\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2014\CfgUsr
Mirko Jurcevic
Message 12 of 22
What do you mean by turn off?? Close the program?? (I'm sorry, I'm not
really good with computers)
Message 13 of 22
Yes. He means to close the Robot first before you delete those files.  [Copy those files as backup for later reference.]
Here is the screenshot of the contents of that folder. My Robot is working fine, so check with your folder.
I dont know what these files contains except that  some of them has color and font information for the Robot. I am curious to know though.
Message 14 of 22
Well, it didn't work... 😞 Robot's driving me crazy...
Message 15 of 22
Mirko.Jurcevic
Have you tried to manually enter Beginning and End coordinates?
Enter coordinates and click "Add".
For example:
5 ; 3
15 ; 4
Add
Mirko Jurcevic
Message 16 of 22
Mirko.Jurcevic
And please, tell us your computer hardware configuration.
Is that Windows 8 you're using?
Mirko Jurcevic
Message 17 of 22
Try creating nodes (by clicking once and by manually giving coordinates once) at some locations and see whether they are being created or not .
Message 18 of 22
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Geometry > Structure Type > select a shell model (silo)
2. Geometry  > Structure type > select the model type you want to work with (2D frame / 3D frame)
Artur Kosakowski
Message 19 of 22
My computer has Windows Home 7, 64-bit. It's a Toshiba Satellite if that helps
Message 20 of 22
Yes, I also tried that and didn't work. Creating nodes doesn't help either because it only creates one node in 0,0, again...
