Robot keeps crashing when I attempt to import the DXF file with section shape
Message 1 of 10
For some reason, Robot keeps crashing when I attempt to import the DXF file. Is there a certain file size limit that it can take? I wouldn't say it's the most complex of shapes but not simple either.
@Anonymous Artur Kosakowski edited the topic from 'Custom Section Propertiesfor better findability and marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Replies (9)
Message 2 of 10
I have simplified the section, but now when I import the file, there is no geometry shown in Robot.
Message 3 of 10
This is the section in question
Message 4 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not able to open this dxf in AutoCAD. How did you create it? Do you have its dwg version?
Artur Kosakowski
Message 5 of 10
Not sure what happened.
Here's the file again, and the DWG as well.
Message 6 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The audited dwg and dxf files.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 7 of 10
Could you please let me know what you've done?
Message 8 of 10
Also is there a file size limit? I have a file that seems to be too big. The dxf file is 1500 kb
Message 9 of 10
I notice also that you've created quite small file sizes. How have you reduced your DWG to just 41kb?
Message 10 of 10
grzegorz.cwiek
Hi @Anonymous
You can clean up your DWG files in 3 steps:
1. PURGE command (use the "Purge all" option
2. AUDIT command
3. -PURGE commmand - this one gives you prompts in the command line, please type "R" for "Regapps" and purge those - in the last DWG there were quite a few registered applications, which may cause problems as they acumulate with time
Hope that helps!
Grzegorz Cwiek
