Robot crashes during calculation
I am currently in the process of building a model and it has been working fine up until now where it keeps crashing when trying to calculate the results.I have tried clearing the temp folder and the cfgusr folder as said in previous posts but still no luck.
Would be great if someone can take a look at my model. Quite urgent to get it finished!
Many thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
Check panels 1321 and 1367 which seem to be incorrectly defined. You should have no issues after  deleting them.
Artur Kosakowski
Thank you very much, just wondering how did you find those panels that were causing the problems?
Artur.Kosakowski
Autodesk Support
Autodesk Support
I have noticed that meshing part of model generation lasts longer than I would expect so I decided to have a closer look at this part. After selecting all panels and freezing meshes I checked if there are still some panels with not frozen meshes which would indicate some possible issue. That's all. No magic applied Smiley Happy
Artur Kosakowski
I see, I only started learning robot last week. Good to know the thought process in case it happens again 🙂
