No mesh in areas of panel
Hello!
I am designing a concrete slab and when I run the model, small areas of mesh seem to disappear, but the model still analyses and produces ok results (with blank areas where there is no mesh):
I have remeshed the panel which works fine, but when I re-run the analysis these empty areas reappear! I have tried this a few times, as well as freezing the mesh but nothing seems to make any difference. Why could this be happening?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you have the same display in 3D and when you switch the story filter off (if applied)?
Artur Kosakowski
Yes, see deflection rsult below with empty spaces
Artur.Kosakowski
Autodesk Support
Autodesk Support
Attach the file and indicate the number of the panel please.
Artur Kosakowski
See model at: https://www.wetransfer.com/downloads/2d9597d995e2e4462728d64bb37edad820130827102342/e856f9
Panel affected is 1004
You have looked at this model previously for me, and I appreciate that there are still a couple of warnings to address but don't think these should affect the mesh!
Thanks for your help
Artur.Kosakowski
Autodesk Support
Autodesk Support
The instability of type 2 should not be ignored. For the display of maps see the attached picture.
Artur Kosakowski
