Reinforcement Design for AS3600
I am trying to use the module for reinforcement design according to AS3600 in Robot 2014.
The message received is that the calculation was done correctly, but then the output for the area of reinforcement does not look correct at all ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
As far as I can see types and parameters assigned to elements of the model do not exist as labels in the project. Try to assign the existing (or define new) types and parameters to elements of the model and then run RC design.
Artur Kosakowski
Hi
I have made use of the standard Type and Code Parameters supplied with robot with Regional settings to Australia.
I still have a problem. The design shows the design forces correct and also the load combination. Then stirrups looks ok, but check for rebar in the columns, it says 0 mm2 or 9 mm2 - this is not correct.
Artur.Kosakowski
Autodesk Support
Autodesk Support
In the results you can see the values of reinforcement that you would theoretically need (required reinforcement) which is none or very low for a column of 800 mm diameter as well as the minimal value required by the code. That is correct. On the other hand the minimal reinforcement should be included in the values of the provided one. I have made such request for the next versions of Robot.
Artur Kosakowski
