robot blank model
robot blank model
Message 1 of 12
robot blank model
My Robot model does not work anymore, It displays a blank page even if the file is 48MB. Has anyone experienced the same issue?
Replies (11)
Message 2 of 12
Rafacascudo
have you tried opening it on "repair mode" ?
Rafael Medeiros
Message 3 of 12
Yes. It says that it has been done with a different version of robot, even if it is not true
Andrea Pasqualetti
Structural Engineer
[Maffeis Engineering SpA]
Maffeis Engineering S.p.A..
Via Mignano, 26
36020 Solagna (Vi) - ITALY
Mob: 0039 (0) 3493909947
Email: [email protected]
Web: www.maffeis.it
Skype: me.andrea.pasqualetti
Message 4 of 12
Rafacascudo
Is " structure"  marked on "Display"
Rafael Medeiros
Message 5 of 12
yes it is
Message 6 of 12
Rafacascudo
In the other thread you you asked about video acceleration. it´s here
If this doesn´t work , can you send us the file?
Rafael Medeiros
Message 7 of 12
it does not work. Can I send the model in private?
Message 8 of 12
Rafacascudo
Andrea,
On the file you sent me directly ,The structure model appears on the file icon ,
but there´s nothing on the file . No bars , no nodes , no panels , nothing.Well at least on screen or tables.
I´m sure the autodesk specialists Artur ,Rafal and Pawel will have an answer for that.
Rafael Medeiros
Message 9 of 12
How can I contact them?
Message 10 of 12
Rafacascudo
They're reading it all
But you can also send them private messages or try official support channel directly.
But this forum is almost always the fastest way to get the correct answers
Rafael Medeiros
Message 11 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Wee need also the file to look at :-).
Rafal Gaweda
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm very sorry but the file is corrupted in such a way that it is impossible to recover it. In case you work in such a way that you open the files from a network location to edit a model I'd strongly suggest to copy the file to a local drive first so that any lost of connection with the file location while working on it is prevented.
Artur Kosakowski
