Robot API query
Robot API query
Robot API query
What is the line of code to be used in the C# code for Robot API to decide, if the contour defined using polyline is to define a Panel or an opening.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Opening is a contour inside panel and it is not meshed
Example code below
Dim Robject As RobotObjObject
Dim Rcontour As New RobotGeoContour
Dim Segment(4) As New RobotGeoSegmentLine
Segment(1).P1.Set 0, 0, 0
Rcontour.Add Segment(1)
Segment(2).P1.Set 10, 0, 0
Rcontour.Add Segment(2)
Segment(3).P1.Set 10, 0, 5
Rcontour.Add Segment(3)
Segment(4).P1.Set 0, 0, 5
Rcontour.Add Segment(4)
Rcontour.Initialize
        DrawPanel = RobApp.Project.Structure.Objects.FreeNumber
        Set Robject = RobApp.Project.Structure.Objects.Create(DrawPanel)
        Robject.Main.Geometry = Rcontour
        Robject.Main.Attribs.Meshed = True
        Robject.Initialize
        Robject.Update
Dim Ocontour As New RobotGeoContour
Segment(1).P1.Set 1, 0, 1
Ocontour.Add Segment(1)
Segment(2).P1.Set 2, 0, 1
Ocontour.Add Segment(2)
Segment(3).P1.Set 2, 0, 2
Ocontour.Add Segment(3)
Segment(4).P1.Set 1, 0, 2
Ocontour.Add Segment(4)
Ocontour.Initialize
        DrawOp = RobApp.Project.Structure.Objects.FreeNumber
        Set Robject = RobApp.Project.Structure.Objects.Create(DrawOp)
        Robject.Main.Geometry = Ocontour
        Robject.Initialize
        Robject.Update
Rafal Gaweda
Hello Rafael;
My situation is as follows.
To create panel or opening, polyline method has been used. In the polyline option we can define the contour to create panel or openings.
My program chooses all the contours from the model and treats them as Panel.
But I want to know which contour has been used to define panel and which one to define Contour/Opening.
I have written the API in C# and want to know which option I should use in my code get the information I am looking for.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
If I understood you correctly, polyline or any set of lines, arcs which are used to create panel \ opening are "converted" by program to contours while creating panels \ openings.
So I guess you need to check whether the Robject.Main.Attribs.Meshed is True or  False
Rafal Gaweda
