API (vba): how to retrieve the section database a bar pertains to ?
xavier_durieux
xavier_durieux
I'm stuck with a problem: I want to know the section database a bar comes from.
I've found a way to do it but it's incredibly time consuming (253 seconds for a 643 bars' model; 69 seconds for a 195 bars' model).
It's certainly due to "LoadFromDBase2" that reads data of the section found (and I don't need to read such data).
See code below.
Is there a way to quickly retrieve the section database a bar pertains to ?
Thanks in advance.
XD
Sub Importer_barres()
Start = Timer
Dim RobApp As New RobotApplication
Dim AllBars As RobotBarServer
Dim AllNodes As RobotNodeServer
Dim CurrentBar As RobotBar
Dim EndNode As RobotNode
Dim StartNode As RobotNode
Dim BarSection As IRobotBarSectionData
Dim i As Long
Dim TNOB As Long    ' Total number of bars
Dim CATA As String  ' Catalogue de profilés
Dim MAT_BAR()
' ------------------------- Initialisation du serveur de barres ------------------------
' ------------------------------- et du serveur de noeuds ------------------------------
Set AllBars = RobApp.Project.Structure.Bars     ' AllBars = Serveur avec toutes les barres
Set AllNodes = RobApp.Project.Structure.Nodes   ' AllNodes = Serveur avec tous les noeuds
TNOB = AllBars.GetAll.Count                     ' TNOB = nb total de barres du modèle
If TNOB = 0 Then
    MsgBox "Votre modèle ne contient aucune barre !", vbOKOnly, "ERROR"
    Set AllBars = Nothing
    Exit Sub
' ----------------------- Enregistrement des barres dans MAT_BAR -----------------------
ReDim MAT_BAR(1 To TNOB, 1 To 9)
For i = 1 To TNOB
    Set CurrentBar = AllBars.GetAll.Get(i)
    Set StartNode = AllNodes.Get(CurrentBar.StartNode)
    Set EndNode = AllNodes.Get(CurrentBar.EndNode)
    Set BarSection = CurrentBar.GetLabel(I_LT_BAR_SECTION).Data
    If BarSection.LoadFromDBase2(BarSection.Name, "AISC") Then
        CATA = "AMERICAN"
    ElseIf BarSection.LoadFromDBase2(BarSection.Name, "CHIN9") Then
        CATA = "CHINESE"
    ElseIf BarSection.LoadFromDBase2(BarSection.Name, "EURO") Then
        CATA = "EUROPEAN"
    ElseIf BarSection.LoadFromDBase2(BarSection.Name, "GOST") Then
        CATA = "RUSSIAN (GOST)"
    ElseIf BarSection.LoadFromDBase2(BarSection.Name, "KOREA") Then
        CATA = "KOREAN"
    MAT_BAR(i, 1) = CurrentBar.Number                           ' N° de la barre
    MAT_BAR(i, 2) = StartNode.Number                            ' Noeud de début
    MAT_BAR(i, 3) = EndNode.Number                              ' Noeud de fin
    MAT_BAR(i, 4) = CurrentBar.GetLabelName(I_LT_MEMBER_TYPE)   ' Type de la barre
    MAT_BAR(i, 5) = CurrentBar.LENGTH                           ' Longueur de la barre
    MAT_BAR(i, 6) = BarSection.MaterialName                     ' Matière
    MAT_BAR(i, 7) = BarSection.Name                             ' Section
    MAT_BAR(i, 8) = CATA                                        ' Catalogue
    MAT_BAR(i, 9) = CurrentBar.Gamma                            ' Angle Gamma
    Set CurrentBar = Nothing
    Set BarSection = Nothing
    Set EndNode = Nothing
    Set StartNode = Nothing
    CATA = Empty
Next i
' ---------------------- Libération des variables ne servant plus ----------------------
Set AllNodes = Nothing
TNOB = Empty
i = Empty
Finish = Timer
TotalTime = Finish - Start
MsgBox (TotalTime)
End Sub
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @xavier_durieux
Try loading all section names from database to RobotNamesArray and then use it for search.
Check this thread.
Rafal Gaweda
xavier_durieux
I'm going to try.
Thanks for the tip !
