Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot analysis running SLOW!
4 REPLIES 4
910 Views, 4 Replies
 Hi all,
Robot analysis is taking a lot of time analysing the model. I wonder what is wrong in my model. I am aware that there are a lot of finite elements in my model. However I am just running the Dead load case and it is just stuck at the stage of 'Applying of loads'. Would it be possible to give me some advice on the model?
Chinnie
4 REPLIES 4
Rafacascudo
I don´t really know where the problem is. Probably on an incorrect load definition .
But it is not on or DL load case .
On Load table , if you delete all the loads assigned to all load cases BUT DL , the model will run perfectly and fast.
Rafael Medeiros
Rafal.Gaweda
in reply to: Rafacascudo
in reply to: Rafal.Gaweda
I deleted the Linear 2p(3D) Loads and it works just fine. Thanks Rafal and Rafacascudo
Rafal.Gaweda
No, you can use "Linear loads on Edges" defining first lines or polylines to be loaded
It works, but as you can see  - sometimes slow.
Rafal Gaweda
Technology Administrators
