Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Rigid Diaphragm Without Thickness
2 REPLIES 2
486 Views, 2 Replies
Hello People
I would like to model a rigid diaphragm but not as a slab, just the diaphragm. Because I would like to place the weight of the slab as a dead load and I dont know if t = 0 is enough to do that.
Regards.
2 REPLIES 2
Rafacascudo
Just Change the panel calculation model from shell (default) to rigid diaphragm. It's on FE toolbar.
Never tried , but Probably not possible to create a panel with zero thickness. And certainly it would not be very rigid . 🙂
Best way to not consider weight for any type of object(bar or panel) is to create material ( job preferences) with weight density equal to zero.
2nd option would be set own weight only for selected elements instead than for all (default)
Rafael Medeiros
in reply to: Rafacascudo
Great idea Mr.
Thank you for answer
