Revit to RSA
Revit to RSA
Revit to RSA
In this file, there are some errors and warnings that I have faced in transferring my model from Revit to Robot, how can I overcome these errors and warnings?Errors and warnings.PNG
Rafacascudo
Select the message and nodes/elements will be highlighted.
isolated nodes - disconnected from the structure. Check them all and if it´s not a modelling mistake , delete them all.
isolated nodes with additional atributes - Same as above . It´s probably an isolated support node
Overlap bars. Bars on top of each other.slect the message , select their nodes , open in another window , and you will easily see where is the mistake.
Instability- correct these warnings/errors and run model again to see if it persists
Rafael Medeiros
how to remove the instability errors?
elements not assigned to any story, will this warning create an impact on the analysis result values?
Rafacascudo
watch webinar 16 on Build your Robot Structural Analysis IQ - YouTube
If you are a RSA beginner , watch them all according to your needs. They are all excellent for learning the software
Rafael Medeiros
