Revit to Robot: varying lateral load on planes e.g. soil pressure on walls
I think this is a bug in when moving surface loads from Revit to Robot.
I have a small underground corridor which I modelled in Revit and I also applied loads in Revit.
I applied varying soil pressure on the walls and when I moved to Robot I noticed that the loads are global z direction.
I also noticed that in the table, they are assigned as "global". to my big surprise, when I changed global to local, the loads stayed graphically the same as before; i.e. in global z direction.
Has anybody else noticed this?
Rafacascudo
Try generating the structure model on analysis options/stucture model tab , and then , on View/display/Loads ,mark " forces generated automatically"
Rafael Medeiros
