Revit to Robot - Nothing appearing in robot
onayohob23
onayohob23
Hi all
I'm trying to export a revit model to robot. On revit it says the export is successful, however I don't see any of the elements in robot and just see a blue background.
Could someone advise on how to make this work? See Revit 2023 file attached.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @onayohob23
Starting from version 2023 you have to create analytical model in Revit before exporting it to Robot.
Use Analyze >Analytical Automation option to do that.
In your model there are no analytical objects (only physical objects are defined).
Please refer to this video
Krzysztof Wasik
onayohob23
Thanks Krzysztof!
