How to create a Custom L-angle Section ?
Joseph_Daou
Joseph_Daou
Hi all,
How can I create a custom L-angle section in Robot for example L-40x40x2 that is not in the database of any country.
Is there a way to create it from other parametric section type?
Thank you in advance.
CaioSaporito
Hi @Joseph_Daou!
You can creat this section in "tools/section definition" using this steps:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Need-help-to-impor...
Or change the existing database that has a similar L shape, like 40x40x3, using this steps:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Is-it-possible-to-...
Best Regards,
Caio
Stephane.kapetanovic
hi @Joseph_Daou
You will find below the list of sections with dimensions to the nearest 0.5mm. Note that some sections are thin-walled.
ID + NAME1 + SHAPE_TYPE + (H x B x EA) mm
AUS
440      40x40x2,5 CA    1006     40x40x2.4
CHIN9
49609    CL40X2          1006     40x40x2
49610    CL40X2.5        1006     40x40x2.5
GOST
3848     гн L 40x2,5x3   1006     40x40x2.5
NZL
3038     CAE 40x40x2.5   1006     40x40x2.4
3074     CAEP 40x40x2.5  1006     40x40x2.4
STAL
9162     L 40x40x2       1006     40x40x2
9163     L 40x40x2,5     1006     40x40x2.5
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
