resultant force acting on a node
saclovitzky
Message 1 of 15
saclovitzky
Is there a way to view the resultant force acting on a node,ie, node 3
Any help will be greatly appreciated
Replies (14)
Message 2 of 15
Simau
Hi @saclovitzky
You may try this API
https://forums.autodesk.com/t5/robot-structural-analysis-forum/local-reactions-api/td-p/13213319
M. Agayr
Message 3 of 15
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Message 4 of 15
saclovitzky
Message 5 of 15
Simau
Macros might be disabled.
M. Agayr
Message 6 of 15
saclovitzky
@Simau ,I cannot open the excel(for wahtever reason).Please see attached model file.
Can you possibly run the API and send me the result in excel file for node 3(resultant force).
Thank you in advanced.
Message 7 of 15
saclovitzky
I open now the apps but just wondering why there's no result in node 3?
Message 8 of 15
saclovitzky
@Krzysztof_Wasik ,the link is no longer valid.
Message 9 of 15
Simau
@saclovitzky
The zipped model is empty.
Send it again
M. Agayr
Message 10 of 15
saclovitzky
@Simau , pls. see attached again
Message 11 of 15
Simau
@saclovitzky
please find results for node 3
M. Agayr
Message 12 of 15
saclovitzky
@Simau ,how do you manage to get the result on node 3, I've tried but I cannot get the result?
Can you show me how?
Message 13 of 15
Simau
@saclovitzky
M. Agayr
Message 14 of 15
bhavani_sankuratri
Hi @saclovitzky ,
Hope you are doing good! I wanted to follow up and see if you had a chance to look into the Simau's post. Please let us know if you still need any assistance on this.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Bhavani Sankuratri
Message 15 of 15
Stephane.kapetanovic
hi @saclovitzky
I hadn't seen your message, and other replies have come in since then.
I had an Excel tool for doing this as well; mine provides the cumulative member forces, in absolute values, relative to another member's coordinate system.
I'll let you take a look at it, hope it helps.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
