Load distribution on concrete slab
I have a two storey concrete structure above an open garage. One side of the building is very stiff with concrete walls and an elevator shaft. The other end of the building consist of steel columns in wooden walls that comes down on a concrete beam - column system in the garage roof. Building floors are concrete slabs resting on concrete walls, elevator shaft walls and concrete columns. When looking at reaction forces in steel columns and some of the concrete walls in the back around the elevator shaft somehow I get an uplift instead of downward facing forces. It looks like the elevator shaft "steals" forces through the concrete slab. Some force distribution towards the shaft is expected as there is it a stiffness center but the final results are not making sense. Any idea as to why this happens? Steel columns are pinned-pinned and slab-wall connections are fixed.
