Restablish a Results file with a model
Good Morning,
I have a results file for a model however, the model was resaved and therefore the link between the reulsts file and model is no longer valid. Nothing has changed in the main model therefore, is there a way to restablish this link? The model take 36 hours to run so I cant afford to re-run it.
Please can someone help
James
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi James,
To try to help I need to have both rtd and _RT files. Will you be able to give me a link to download them?
Artur Kosakowski
Artur,
Please find below link to both files:
http://we.tl/ZJHkXS0tzt
Thanks for your help.
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Rename rtd file (e.g. to 1_... . rtd)
2. Change the extension of bak file to rtd
3. Open this rtd (make sure _RT)  is in the same location
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Brilliant! Thanks Artur! Smiley Happy
Artur.Kosakowski
Autodesk Support
Autodesk Support
In addition: make sure you set the multi-threaded solver in Job Preferences. It is much faster than Sparse which is used when you have Auto selection.
Artur Kosakowski
