05:44 AM
Hi Autodesk
1 I am designing a portal frame in Robot but am not sure how to get the apex bracket as a haunch as it only allows a full beam to beam connection and not a haunch as reqd. Can you tell me how to do this?
2. Also I have tried to input the connections in connection design but I am not sure it has taken account of my inputs. When you input the bracket connection how do you get it to run this and verify if ok?
3. Is there a special section of the tutorial for portal frames as I could not find anything?
Thanks Patrice
