RENAME GROUP
12 REPLIES 12
Message 1 of 13
petite24021989
829 Views, 12 Replies
RENAME GROUP
Hi!
In model, I create a group with a default name, and I change the default name in to new name "DAM MONG", but the program notifies that the group with the name specified already exists, while there isn't any group with name "DAM MONG" exists in my model.
Thanks!
12 REPLIES 12
Message 2 of 13
Romanich
in reply to: petite24021989
Hi @petite24021989 ,
Please share the file.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 13
petite24021989
in reply to: Romanich
hi @Romanich
Message 4 of 13
Romanich
Open the table Group of Objects and you will see all of your groups:
As you can see the group with the name DAM MONG already exists. You can either delete this group or modify the list of objects. Also, you can quickly check if the group is exist by pressing the Bar Selection combo box:
The bottom line is that empty groups are not shown in the Object Inspector.
Roman Zhelezniak
Message 5 of 13
petite24021989
thanks @Romanich a lot!
Message 6 of 13
hi @Romanich!
Could you please instruct me how to delete existing group in model?
Thanks!
Message 7 of 13
Romanich
The solution is not straightforward (and also it is not possible to delete empty groups using API!) Please check this video:
Dear @okapawal please add the possibility to delete the empty groups in the table as it implemented for load records:
Roman Zhelezniak
Message 8 of 13
okapawal
Yes, it is a good suggestion.
Or maybe better solution would be to remove empty groups automatically by the program as they are not displayed in the dialog nor inspector?
Waldemar Okapa
Sr Product Owner
Message 9 of 13
Romanich
in reply to: okapawal
Some simple methods to delete empty groups should be available. At least to do it using API.
Roman Zhelezniak
Message 10 of 13
petite24021989
Thanks @Romanich very much!
Message 11 of 13
okapawal
This issue has been resolved with Robot Structural Analysis Professional 2023 release.
Please find more in the Release Notes
Regards
Autodesk Robot Structural Analysis team
Waldemar Okapa
Sr Product Owner
Message 12 of 13
Romanich
Hi @okapawal ,
Thanks for fixing this bug. Now empty groups are visible in the Object Inspector and can be deleted from there. However, it seems that the group (empty or with elements) cannot be deleted using API. I mean that the required method is still not implemented.
Roman Zhelezniak
Message 13 of 13
thank @okapawal and @Romanich so much!
