Reinforcement change table
karolisKZK6A
Message 1 of 9
karolisKZK6A
After I've updated a version of ROBOT the Change of reinforcement in required reinforcement module seems to not work properly or I am missing something. I've got a beam of which deflection is exceeded. I increase required reinforcement area and click apply. After I press verify, number of bars goes back to what it was before I've changed required area and deflection stays untouched.
How do I make it work?
Replies (8)
Message 2 of 9
karolisKZK6A
Have nobody had this issue before?
Message 3 of 9
Simau
Could you zip and share your model
M. Agayr
Message 4 of 9
karolisKZK6A
Sure. This is a download link:
https://fileport.io/k7JF382vURrX
Message 5 of 9
Simau
I never used requiered reinforcement with previous Robot releases.
With Robot 2025, i got same behaviour as you.
M. Agayr
Message 6 of 9
karolisKZK6A
Thank you for taking a look. Do you think it's a 2025 version issue and it is not on a user side?
Message 7 of 9
CaioSaporito
Hi @karolisKZK6A.
Same issue here. Im using 2025 version.
Best regards,
Caio
Message 8 of 9
karolisKZK6A
Hey, thanks for looking into it.
Yesterday I have tried installing all available versions from 2025 up to 2022 to check for this issue. Every single version of Robot has this. This is so weird... I had an old version of 2017 and it worked fine over there. I will probably try to contact Autodesk tech support and see, whether they have any solutions to this.
Message 9 of 9
CaioSaporito
Yesterday I installed the "2026 preview" version and same issue happend.
@Konrad.O Could you take a look deeper in this issue?
Best regards,
Caio
