Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Reduced Panel Results vs reactions
4 REPLIES 4
rb_s-90-k
176 Views, 4 Replies
Hi I have tested a wall with hand calculation and the loads are the same as the support reactions (linear support integral value). However when comparing this with reduced panel results i am getting much smaller results than expected. What is the reason for this?
See image attached - same load case same panel
Any thoughts welcome!
Labels (1)
4 REPLIES 4
Rafacascudo
in reply to: rb_s-90-k
Hard to tell without seeing the model.
Maybe there are loads coming from a slab supported in these same nodes as this wall?
Zip and attach the model , if possible
Rafael Medeiros
rb_s-90-k
in reply to: Rafacascudo
Test model attached @Rafacascudo
Rafacascudo
As I suspected the extra load comes from the adjacent wall. If you split the supports , then you can see better how the reactions are really distributed.
Test model attached
Rafael Medeiros
rb_s-90-k
thanks
Technology Administrators
