Hi I have tested a wall with hand calculation and the loads are the same as the support reactions (linear support integral value). However when comparing this with reduced panel results i am getting much smaller results than expected. What is the reason for this?
See image attached - same load case same panel
Any thoughts welcome!
Solved by Rafacascudo. Go to Solution.
Hard to tell without seeing the model.
Maybe there are loads coming from a slab supported in these same nodes as this wall?
Zip and attach the model , if possible
Rafael Medeiros
As I suspected the extra load comes from the adjacent wall. If you split the supports , then you can see better how the reactions are really distributed.
Test model attached
Rafael Medeiros
