Reaction-Seismic analysis-Larger vertical forces without vertical acceleration
6 REPLIES 6
541 Views, 6 Replies
Hello everybody,
I have modelled a slender, rectangular based steel tower with the height of more than 20 m. I made the modal analysis and it gives 11 modes, which look correct.
After I made a seismic analysis according to IBC 2012. I attached a picture about the resulted reactions for the 4 supports in case of 1*X+1*Y.
My question is how it is possible, that without vertical acceleration(!), how did the vertical forces increase?  Initially, from the self-weight it was 4*~17.8kN=71.20kN, now at this case when the 2 horizontal excitation happened it is 4*~(58.6-58.9)kN=235kN...
Thanks in advance, and I appreciate an early reply if possible.
6 REPLIES 6
In addition I thought it because the moment, but I am not sure about that regarding the results' table.
Rafal.Gaweda
It seems you missed setting of combination sign \ main mode.
See slide 28 and 41 in webinar 7
https://www.youtube.com/watch?list=PLY-ggSrSwbZqow_60fiqJwS69mg1nQMzk&v=3G5NwyDSzxs
without signing - look at sum of reactions \ sum of forces in Reactions table
Rafal Gaweda
in reply to: Rafal.Gaweda
Thank you for the answer Rafal!
I did now these steps and I got the results. I did it now with another tower as well, which is triangle based (also a slender tower). But now another question just arised for me. I guess it is a basic static.
The reaction from self-weight is ~30kN and I git now the attached results.. How the static equilibrium appears? If I have larger vertical forces (because of moments) we still need the balance and I don't see that with such moments.
I can send you the model if you can attach an email address or here.
Thank you very much!
Dear Rafal, I guess I found the balance that I am looking for.
However, some explanation would be welcomed according to this phenomena: why did the vertical forces increased ? Why do we need this signed mode calculation?
Rafal.Gaweda
Set  modal case correctly:
or
to get
Rafal Gaweda
That was again really helpful, thank you. I appreciate your time and effort! I got the results, that you have also got.
What I did before, I used the percent of mass participation limit with 90% of the mass. Why this type of calculation gave wrong results? And why we had the problem without the signed modes?
