reaction descriptions
ByrnePM
ByrnePM
Does anyone know any way of displayin the reaction descriptions so that they are not a jumbled up mess on the screen every time a load case is selected ?
Dear,
According to what I know, you cannot control descriptions appearnce on the screen. In some cases where you have many supports, descriptions in acceptable size (Can be read) need a space more than the screen space.
I advice you to view support reaction from reaction tables.
I hope that I helped you.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Tha same way like shown below you can move most of the labels in Robot; also results values
Rafal Gaweda
agu.kirss
Community Visitor
Community Visitor
Hello
I have another problem though, I am trying to move the value label, but it does not select it, the label does not turn blue when I hower over it.
What can cause that problem?
Best regards
Agu
Rafal.Gaweda
Autodesk Support
Autodesk Support
Should work.
If not clear robot cfgusr folder and \ or open file in repair mode
Rafal Gaweda
