Re Null Section Properties of Bar
Good day to everyone!
I use vba to create bar labels/sections using the following piece of code:
  Dim rLabel As RobotLabel
  Dim rBSD As RobotBarSectionData
  Dim rBSCD As RobotBarSectionConcreteData
  Set rLabel = robApp.Project.Structure.Labels.create(IRobotLabelType.I_LT_BAR_SECTION, secNme)
  Set rBSD = rLabel.Data
  rBSD.ShapeType = IRobotBarSectionShapeType.I_BSST_CONCR_BEAM
  Set rBSCD = rBSD.Concrete
  rBSCD.SetValue IRobotBarSectionConcreteDataValue.I_BSCDV_BEAM_B, CDbl(barW)
  rBSCD.SetValue IRobotBarSectionConcreteDataValue.I_BSCDV_BEAM_H, CDbl(barH)
  rBSCD.SetReduction True, 0.35, 0.35, 1#
  robApp.Project.Structure.Labels.Store rLabel
I also use the following piece of code to create bars object:
  robApp.Project.Structure.Bars.create fBarNo, node1Num, node2Num
  robApp.Project.Structure.Bars.Get(fBarNo).SetLabel I_LT_BAR_SECTION, barSec
When the code is executed, the values of Section [Properties] in Object Inspector in RSA are all null as shown in the attached image.
Solution to this problem will be greatly appreciated.
Bar Section Properties
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example:
    RBSD.CalcNonstdGeometry
    RobApp.Project.Structure.Labels.Store RLabel
Rafal Gaweda
Thanks! Your answer worked.
