understanding local axes in one way ribbed hollow block slab
Message 1 of 9
I have one way ribbed hollow block slab. I want to represent this ribbed slabs using deck slab (one way) on orthotropic slab with ribbs in y-global direction with beams around. After calculation made, in the resutls maps how can I understand Mxx and Myy so no moments in x-global direction?
Replies (8)
Message 2 of 9
Rafacascudo
On Results/maps set direction X to cartesian X global.
this way Mxx will be moment in the xz plane and Myy will be moment in the yz plane.
before that ,be sure you set the orthotropic direction correctly.
Rafael Medeiros
Message 3 of 9
But how to set the orthotropic direction correctly?
Another question please:- why Mxx or Myy is in negative sign in mid panel and +ve at edges ?
Message 4 of 9
I want the ribbed slab moments resulted from RSA the same as calculated manually. then the loads to be transferred to surrounded beams as manual.
Is there any method to make load patterns (live load combinations in slabs) in RSA like SAFE program?
Message 5 of 9
Rafacascudo
for orthotropy direction see below
moment sign in maps  is according to panel local Z direction . If it is positive , the moment is tensioning the panel Z+ direction side.
Rafael Medeiros
Message 6 of 9
thank you very much.
How can I delete moments in non-continuous edges of slabs?
Message 7 of 9
Rafacascudo
Delete or make it zero? I dont clearly understand what you want.
Maybe a screenshot would help!
Rafael Medeiros
Message 8 of 9
In end spans slabs, how can eleminate the moments (zero moments) to be similar to manual calculations?
Message 9 of 9
AhmedZA
Add linear releases to Edge of slab
