RC beam design problem
3 REPLIES 3
StefanoPasquini6790
474 Views, 3 Replies
Good morning everybody,
I'm having problem with the design of the rc beam 130 in my model. I have to design one rc beam and one rc column, for all the user defined load combinations (a lot, due to italian regulation), but when I run the calculation I have always this message:
Probably there's something that I'm doing wrongly, I'm not an rc expert user, my daily job is 99.5% made of steel.
Thank you in advance for your help.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
3 REPLIES 3
Simau
in reply to: StefanoPasquini6790
Hi @StefanoPasquini6790
I run RC claculation under BAEL91, and i got a first waring before your's, saying that shear from truss (IPE) can't be taken into account.
M. Agayr
StefanoPasquini6790
in reply to: Simau
Hi @Simau,
this message was related to the simplified combination rules. In my model I have some elements (bracings) in only tension/compression behaviour that can't be taken into account to define the simplfied combination. When you erase the auto combination generation, and leave only the manual combination, this message disappear and the problem of rc design remain.
Thank you for your time.
PasProStudio
The issue is due to the flatness of bar (130) and the indicated panel in the attached capture. If you try to correct the flatness of the panel and redefine this bar gain .then every thing will be like charm.
The corrected file is attached
Refaat
Technology Administrators
