Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
"The Parameter is Incorrect" Error Message
2 REPLIES 2
anthonymctigue
1285 Views, 2 Replies
Morning all,
I am having difficulty viewing the "Foundation Note" after completing a pad foundation design run.  The "Foundation Note" seems to display fine until I run the calculation however, when complete, I get an error message which states "The Parameter is Incorrect" (see attached screen capture video for more information).  The strange this is that the "Foundation Note" does display correctly before I run the calculation as can be seen in the screenshot.  I did not have this problem yesterday and the only thing I have changed since was to add in more footing types.
I have followed the steps in the forum post below but have not been able to resolve the error.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/parameter-is-incorrect/td-p/4335783
I have tried opening on another machine in the office and this does not happen so I presume this means it is something to do with settings on my machine?
2 REPLIES 2
I found the solution.  It was a simple as clicking "Tools -> Customize -> Open Layouts from Template"
Anthony
Hi @anthonymctigue
Thank you for posting the solution.
Artur Kosakowski
