user automatic load combinations
memoalcr
Message 1 of 14
memoalcr
Do you have an example on how can one create a "user atomatic load combinations"? The code combinations in Costa Rica are slightly different than the one RSA has built-in
Replies (13)
Message 2 of 14
Rafacascudo
I´ve never done it but I think it´s here where you create custom load combinations
Rafael Medeiros
Message 3 of 14
memoalcr
I played with it but could not get it to work. In my opinion RSA HELP needs an example not just the description. So if anyone has an example out there it would be greatly appreciated.
Message 4 of 14
Rafacascudo
Did you save it with another name?
Rafael Medeiros
Message 5 of 14
memoalcr
No
Message 6 of 14
Rafacascudo
so do your modifications ,save it with another name and select it from the list as your load regulations code. It should work
Rafael Medeiros
Message 7 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Like Rafacascudo mentioned strart from any existing in Robot code combination which is the closest to your country regulation and modify it according to your needs (create subnatures if needed ; adjust factors ; select \ set fomulas)
Hint: all regulation files are text files so you can also edit them in notepad and have entension rgl.
Default location of them :
c:\Users\All Users\Autodesk\Structural\Common Data\2015\Rgl\
It is recommended to save user rgl file in such folder:
c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2015\CfgUsr\
Rafal Gaweda
Message 8 of 14
maheshyadav444
I have problem on Automatic load combination. I attached my model. Please suggest how can i create load combination according to euro code?
Message 9 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @maheshyadav444
Go to Loads menu \ Automatic Combinations -> Full automatic combinations, press More, press Generate, calculate model.
Rafal Gaweda
Message 10 of 14
maheshyadav444
Sir, it generate SLS only so how can I generate ULS also?
Message 11 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @maheshyadav444
Are you sure?
Rafal Gaweda
Message 12 of 14
maheshyadav444
sir,  don't know in my system its look like  and there is only one ULS so how can I reset my Robot structure professional analysis?
Message 13 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @maheshyadav444
Scroll down to the end of list
I am attaching my file, just in case.
Rafal Gaweda
Message 14 of 14
maheshyadav444
Thank you very much
