"encountered an improper argument"
stosto6666
Message 1 of 12
stosto6666
I am having this error message pops up "encountered an improper argument" when trying to save some files on specific location to my computer.Finally file is saved but the message irritates me so much.
I have win7-64 with ARSAP2013. So the question: How to fix that.
Thanks in advance.
Replies (11)
Message 2 of 12
Romanich
I confirm this issue  when  working in English language version of Robot.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
We will try to investigate what is causes the display of this message but we need the files it happens for as well as the exact step by step descriptions of actions to follow. What are the regional settings of Windows?
Artur Kosakowski
Message 4 of 12
Romanich
Hi Artur,
Regional settings of Windows is Russian. It happens with in any file.
Roman Zhelezniak
Message 5 of 12
stosto6666
I confirm this. I mean what Romanich said in message #4. When You try to save any file in for example: C:/ My Documents/My Projects/....../ it happens. When You open the same file and try to save on Desktop no problem at all.
Message 6 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Any chance for the following test on your computers:
1. Change regional settings to e.g. English
2. Create a new user with no Cyrillic letters in its name
3. Use Robot and check if you still have the same situation
Artur Kosakowski
Message 7 of 12
Romanich
My user name already in English, but when I change settings for Canada - problem disappeared. Then returned it to default - also disappeared. Very interesting.
Roman Zhelezniak
Message 8 of 12
stosto6666
I do 2 and 3 without 1. It works. All folders through path to the exact file must have no Cyrillic letters.
Thanks.
Message 9 of 12
Artur, you looked pretty grumpy in your profile pick bro.
Message 10 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thank you. Most likely taken that they when I encountered an improper argument. Smiley Happy
Artur Kosakowski
Message 11 of 12
encountered an improper argument" in coral
Message 12 of 12
3. Use other Font  and check if you still have the same situation
